I am waiting for your reply please.
How to enable homing in GRBL setting.
In other word how to rectify red line shown in picture I have limit switches in k40
According to your knowledge its minor changes in both power supply but I am newer and have little bit knowledge about it.
So please help me how to wire up shown power supply.
I have already visited that page here he clearly mentions about connections of pin G & IN in K40 power supply I also know about pin P+ & G.
I am confused on connection of pin K-, K+, L, 5V,G and 24 V?
Sorry i came again to disturb you.
Homing is enabled in GRBL and issue is rectified almost.
Now i am facing a new problem which also relate to homing.
When axis go to homing position its halted and did not come back and a message came at LightBurn console is shown in picture.
I used limit switches in Normally Open Condition, 2ndly when it move to seek homing motion of motor is very slow.
Please guide me in this regard.
I connect it as shown in picture. Now issue is when i fire up laser from light burn 1stly i need to press fire button then push K- and K+ then laser tube fire up for testing.
when i put drawing and give command to lightburn to run job in MKS DLC32 Light up indication but laser tube did not work. please help me how to resolve it. I did not connect L pin with anyone.
For test check i Connect L Pin with CNC Spindle Negative pin but there is no change in behavior of Laser Tube.
Hello, I came again to disturb you.
I give some test job to My Laser machine (K40 under upgradation with MKS DLC 32 V2.1) before starting the job laser machine is at homing position, it started the job and after competition of job Y gantry touches the limit switch this massage shown in console.
According to my little bit knowledge Y axis gantry did not comeback at which position it started the job.
I change $27=8.000, $27=7.000, $27=6.000, $27=5.000, I tried these commands also but no change in behavior of machine. Sometime another massage displayed in console which is
as i am remembering/recalling of memory about my failure is when i press fire on LightBurn and connect K- and K+ pin laser tube fire up.
But when i gave some sketch to draw the laser tube did not fire up because i did not connect of short K- & K+ pin.
