Neje Head on Ortur Laser Master
Hey Guys, im planning to buy a Neje Laser Head. Actually i own a Ortur Laser Master 2 with a 15w head.
I just want to replace the head, is the Neje Head working out of the box?
Heres the Link of the Neje Head
https://www.amazon.de/dp/B08F73W84T/ref=cm_sw_r_oth_api_i_M5Q07TDPHKBNEF4PHW7Z?psc=1
@LightBurn can you mabye fastly reply?
Out of the box, the short answer is No. The Neje module has a 4 wire plug and the Ortur has a 3 wire plug. If you are able to do some easy rewiring, than yes they will work together. You would have to splice Red-Red, Black-Black, and White-Yellow. Green is not needed per the listing.
Here is a topic on adding the larger Neje modules to the Ortur, may not be the same module you are looking at, but covers the rewiring needed.
