A powered hub is generally a good idea for any of these USB powered controllers, it improves signal integrity and provides some power supply isolation (at least by reducing the USB power load).
just ordered one. will try that next
Today I tried with a powered USB hub, but got the same issue. After 76 min it stopped.
@rocinstruments Which USB hub did you buy?
I will be getting mine this afternoon and will also try: Amazon.com
Sorry for the delay. I was TOLD that I was not going to turn a computer on this past weekend.
The hub that I bought was Compaq unknown model some 15+ years ago. Yah, I know that makes me somewhat old, but it is just an old Compaq USB hub purchased to deal with a very similar problem with my Shopbot back in the early/mid 2000âs.
Sorry I donât have any more than that.
using hub, project still stopped dead
We are still having the same issue
Read in another tread (Neje Master 2S Plus stops after 40min with LB - #2 by TomWS) that switching from laptop to PC solved the problem.
Tried the same but got the same problem.
The only difference is that on the PC it took about 108 min until it stopped while on the laptop it always stopped at about 70 min.
Found this info on the NEJE site:
NEJE MAX problem with lightburn Evanator (2021.5.21)
Regarding the problem of max machine interruption in lightburn mode; among the 100 machines in March, some of them may have unstable factors. NEJE please contact customer service email, service@neje.shop, if you encounter this problem, Initially, it can be solved by updating the firmware. If it cannot be solved, NEJE will send you a new motherboard for free. NEJE is very sorry for the inconvenience caused to you! This problem is due to unstable factors caused by the shortage of chips. NEJE is committed to providing better services!
So I made the firmware update, and it seems to work now. Did only one project since, but that went through until 100%.
Thank you for this update. ![]()
Here is the link to that posting: https://wiki.nejetool.com/doku.php
How do we get them to replace the main board this is our exact senerio they want videos after videos
To be honest, I have no idea. We do not make, sell or service this hardware. We are LightBurn, a software development company.
One problem fixed, but now I have another.
I have a drilling machine in the same room as the laser.
They both are not on the same wire, but when the laser is on, and I turn the switch on the drilling machine, the laser loses the connection, then reconnects and returns to home.
How can that happen?
So anyone who has the stopping problem, should also check if it is not caused by another machine.
What do you mean ânot on the same wireâ? Are they on the same branch circuit (they use the same outlet or circuit breaker)?
This can happen easily if you have a power dip on the branch circuit (like when you turn on another machine on the branch and itâs a weak circuit).
If you plan to run the laser while running other equipment I recommend that you get an Uninterruptable Power Source (UPS) to power your laser and your computer. It probably doesnât need to be more than 400VA and will isolate your setup from any power dips and will actually allow you to run if you have a power outage while burning.
Note that this is generally independent of which Laser system you have (although larger CO2 lasers will require large UPS units).
Make sure the UPS is rated for continuous voltage output. Some switch over only after an outage and by then youâre back to where you started.
No, they are not on the same branch circuit. The laser is on a 230V wire and the drilling machine on a 380V wire.
But now I think I have found the solution (which I really donât understand
I recently bought a powered USB Hub, because some mentioned that the HUB will solve the problem, that the laser will stop mid-project. So I connected the laser and the webcam with the hub.
But when the laser was working, and I started the drilling machine, the USB lost the connection and the laser stopped.
When I connect the laser directly to the laptop and not via the USB-Hub, it works.
But I donât understand why it stops when connected with the USB-Hub.
Now the laser does not stop anymore, but it happens another problem.
After a while (1-2 hours), the motor starts to jerk and then and then the line is shifted.
This makes it impossible to laser larger projects.
Here are my settings:
$0=10
$1=200
$2=0
$3=7
$4=0
$5=0
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=1
$23=1
$24=100.000
$25=1000.000
$26=250
$27=1.000
$30=1000
$31=0
$32=1
$100=80.000
$101=80.000
$102=80.000
$110=4000.000
$111=4000.000
$112=4000.000
$120=200.000
$121=200.000
$122=200.000
$130=810.000
$131=460.000
$132=150.000
to me it sounds your controller runs hot
