martintg
(martin marley)
April 7, 2021, 9:52am
1
I am trying to cut an accurate 50x50mm square (as a test) the software cuts 50x60mm. The machine cuts perfectly using GRBL but not in Lightburn. Please advise
DavidF
(David Fenton)
April 7, 2021, 2:45pm
2
What size of error are you getting? if it’s small, are you sure you don’t have a kerf set for that layer?
Cheers
David
justginbg
(Gary Rowlands)
April 7, 2021, 4:16pm
3
There are some simple calibration stops to go through in order to set the step size.
This sets it out quite well.
Hope it helps
Gary
Mooseuk
(David Rodgers)
April 7, 2021, 4:29pm
4
There is a fantastic tool in Lightburn to calibrate the axis.
Hit ‘Edit’ tab then go to machine settings then ‘Calibrate Axis’ and follow the procedure.
Hope this may help
Rick
(Technical Evangelist)
April 8, 2021, 8:46pm
6
The OP has an Ortur running Grbl. You are posting a potential solution for an entirely different, Ruida DSP control system.
Rick
April 8, 2021, 8:50pm
7
Share how you have things set up. We are going to need a bit more information to offer any real direction.
Have a review of this post to understand what and why we need data to be of help.
Folks,
When asking for support for LightBurn via this forum, email or anywhere else, please keep the following tips in mind for the fastest and most helpful answers.
[How to Ask for Help and Troubleshoot Fast]
Please provide these details:
What machine do you have?
What controller does it have , and what firmware it is running?
Are you running the latest version of LightBurn?
Is the issue new, or has it happened before? What kind of computer is it, and what Operating System is i…
