Problem when machining pockets
Hello everyone,
I have a small problem when machining circular pockets… I’m using 2 mm passes, but after each pass, the spindle rises above the workpiece, which wastes time. I’ve changed the project’s safety settings, but nothing has changed; the spindle still rises above the material.
Has anyone else experienced this and found a solution?
Best regards
Link to video
What is your “Pocket Lift Height” value set to in your project?
That value, if it is not zero, is the height above the floor of a pocket to lift to when traveling within the pocket.
You haven’t posted any screen shots of the project settings, your pocket settings, or said which version of MillMage you’re using. You should do those things when posting a question so it’s easier for us to help you.
Hi,
Here are the settings project.
Regards
Hmm… that is odd - that should work as expected. Can you email your project to support@lightburnsoftware.com so we can have a look? Include a link to this thread.
I’ve just sent email.
Regards
Might also be related to this thread: Pocket Operation Ignoring Pocket Lift Height
Ok, I’ve figured out what’s happening here and it’s been fixed for the next update.
