I seem to have started having problems following a recent update. I’m currently using Lightburn 1.0.02 but I have a feeling the problem started when the new .lbrn2 file extension was introduced.
Most of my Lightburn projects are in the old .lbrn format. If I try to open them from Windows File Explorer (with Lightburn not running) then open fine.
However, if I already have Lightburn open and try to open one of those from within the program itself, it just hangs. I can close the Lightburn window, but it carries on running in the background. Task manager is showing Lightburn using approx. 25% of the CPU and I have to “End Task” it to get it working again.
Annoyingly, it doesn’t happen 100% for the time but it’s certainly almost all of the time.
I suspect a fix would be to open every project and save it in the new format but I have 100’s and don’t really fancy doing that. Plus, that doesn’t fix the problem.
Is there a debug log I could check (and post) to help nail down the problem?
