When I try to burn on a cup horizontally I get a bunch of lines. However if I burn vertically (top to bottom of the cup) it seems to work fine. The rotary seems does turn the cup. I am using the XTOOL D1 with the rotary attachment on a Windows 10, 64 bit computer. My Lightburn software is version 1.104. I am very new to this and this is my first attempt at this so I’ve never been able to make a cup with this.
Please post some pictures of what you are seeing.
I’ll move this to the correct group and tag it.
I hope you get some traction and are able to move toward your desired outcome.
I’m having the same issue. Were you able to find a resolution?
No not yet. I can only use the software that came with it, which is very plain. I really want to use it with lightburn
i was told by light burn it was due to my firmware update on the xtool d1 and that i had to revert the firmware to D1_firmware_V40.30.002.01B1_20220110.bin
How do I do that
We have a support person from xTool helping out now. @Anwen
Their post here may help you with your firmware change.
