Is it advisable to factory reset my rudia controller? I want to rule it out as a possible source of my quality issues, however i dont know all the repercussions to this.
Not really, unless you have access to all the settings that the manufacture of âyourâ laser used to configured this controller. A âFactoryâ reset will reset the Ruida back to the original configuration set at Ruida and is not set up for your hardware.
If you have not been through this process before, it can be a bit of work to restore âyourâ laser configuration.
Tell us what is happening, what you have tried and what the results are and we might be able to suggest some options.
Ok, thank you. I have a boss laser. I will wait for them to help and advise if it is even needed.
Good approach. Once you get some feedback from the nice folks from Boss, fire back if we can help further.
much appreciated, thank you.
Once you had you X and Y calibrated, you did back up your vendor settings⌠right?
unfortunately i did not create a backup.
Boss should be able to provide the factory settings as they set them prior to shipping. Have you been told by your Boss Technical Support Rep. that you need to change the controller settings?
Luckily, there are some basics. If you go to Mattâs web site and watch his controller upgrade video, you can get enough to get you semi operational. I used them when I put a new controller in when I switched from Top Wisdom to Ruida. They werenât perfect, but close enough to get me operational.
Also, disconnect the stepper output from the controller, it will keep them from hitting the wall while you are programming. I hooked up an external 24V DC supply to mine before I even installed it to âpre-programâ it.
Good luck.
No I havenât. I tried reaching out to them today but they did not get to my call because a few tech support agents were on calls.
