Using files that previously worked.
When I hit Start it makes a pass from left to right and stops. Laser comes on at end of pass
I getthis message
“Starting stream
Stream completed in 0:00
<Idle|MPos:47.333,26.668,0.000|FS:0,0|Ov:100,100,100>
ok
Starting stream
Layer C00
error:1
G-code words consist of a letter and a value. Letter was not found.
On or near line 0:
Job halted
ok
ok
ok
ok
ok”
If I hit FRAME it makes a complete loop/
Travels fine in GRBL
What did I screw up???
Thank you for your help
This reads like it could be a GRBL dialect difference. What specific controller are you using? And what have you configured LightBurn to?
I assume this is a new setup?
If you search the internet for ‘grbl error 1’ you will find that it is choking on the first line of code sent to it.
This is the line number “On or near line 0”
Something in that first line has a ‘letter that was not found’. Some type of information…
When you boot your machine, can you screen copy or show the version of the grbl firmware?
The version is v4.6.0
Not a new set up. Worked fine for months. Hadn’t used it for couple of months. When I went to use it I was adjusting the focus by lowering “Y” axis and it bottomed out. This locked the GRBL. Unlocked the GRBL and this problem started. All using files that worked fine before
Could not find any information on the ‘Big Bang’ type listed in your profile, so I don’t know what kind of machine or it’s configuration to be of much help.
If it worked then failed, there are usually two options that are most prevalent. Generally these electronics are pretty tough. But it’s always a possibility that you have a hardware failure.
I’d check to ensure you have everything secure. Things come loose over time.
Does you machine ‘home’ on all three axes?
No name on machine. Bought on amazon from " MYSWEETY"… Yes it homes on all axes. Works on GRBL only problem is with Lightburn when I hit start. Motion is fine with frame
What does this mean? Are you referring to laserGRBL? If so, then this is certainly fixable.
Have you tried re-adding this device in LightBurn? Wondering if somehow your configuration got corrupted.
Else I’m wondering if that crash on the Y-Axis burned something out.
Can you click ‘Save GCode’, save is as a text file, and attach it here to this thread?
Yes laserGRBL. I tries shreding and reinstalling laserGRBL, didn’t help. With lightburn all the stepmotors work fine with move tool. Even when I hit the frame tools it moves around the box as it should. Machine works fine when using laserGRBL Not sure how to “re-add” it lightburn???
Not sure how to do that???
Click this:
Save the file somewhere you can find it, like your desktop, then click this:
(or just drag the file into a reply)
My page looks like this
You are working in ‘Beginner Mode’, that is why you don’t see that option. Click the ‘Gears’ icon at the top-center of LightBurn to expose the general LightBurn settings and turn that ‘Off’ (red). You should now see the option to ‘Save GCode’ displayed.
Now the SaveG code isn’t highlighted
Are the rest of these settings OK?
Do you have a file loaded or some shape defined in LightBurn?
If I don’t get back to you tonight I need to get to bed and getup at 2AM. Thanks fo ryour help so far
Have several that have all worked in past…not now
I meant when you took that screenshot with the grayed out buttons. Was there a file loaded then?
; LightBurn 1.0.06
; GRBL device profile, current position
; Bounds: X-0.42 Y0 to X25.53 Y11.86
;USER START SCRIPT
33
;USER START SCRIPT
G00 G17 G40 G20 G54
G91
M4
; Scan+Cut @ 1000.002 mm/min, 60% power
M8
G0X0.7422Y0.0032
; Layer C00
G1X0.0164F39.37S0
G1X0.0449S600
G1X0.0165S0
G1Y0.004S0
G1X-0.0165S0
G1X-0.0449S600
G1X-0.0164S0
G1Y0.0039S0
G1X0.0164S0
G1X0.0449S600
G1X0.0165S0
G1Y0.0039S0
G1X-0.0165S0
G1X-0.0449S600
G1X-0.0164S0
G1Y0.004S0
G1X0.0164S0
G1X0.0449S600
G1X0.0165S0
G1Y0.0039S0
G1X-0.0165S0
G1X-0.0449S600
G1X-0.0164S0
G1Y0.0039S0
G1X0.0164S0
G1X0.0449S600
G1X0.0165S0
G1Y0.004S0
G1X-0.0165S0
G1X-0.0449S600
G1X-0.0164S0
G1Y0.0039S0
G1X0.0164S0
G1X0.0449S600
G1X0.0165S0
G1Y0.0039S0
G1X-0.0165S0
G1X-0.0449S600
G1X-0.0164S0
G1Y0.004S0
G1X0.0164S0
G1X0.0449S600
G1X0.0165S0
G1Y0.0039S0
G1X-0.0165S0
G1X-0.0449S600
G1X-0.0164S0
G1Y0.004S0
G1X0.0164S0
G1X0.0449S600
G1X0.0165S0
G1Y0.0039S0
G1X-0.0165S0
G1X-0.0449S600
G1X-0.0164S0
G1Y0.0039S0
G1X0.0164S0
G1X0.0449S600
G1X0.0165S0
G1Y0.004S0
G1X-0.0165S0
G1X-0.0449S600
G1X-0.0164S0
G1Y0.0039S0
G1X0.0164S0
G1X0.0449S600
G1X0.0165S0
G1Y0.0039S0
G1X-0.0165S0
G1X-0.0449S600
G1X-0.0164S0
G1Y0.004S0
G1X0.0164S0
G1X0.0449S600
G1X0.0165S0
G1Y0.0039S0
G1X-0.0165S0
G1X-0.0449S600
G1X-0.0164S0
G1Y0.004S0
G1X0.0164S0
G1X0.0449S600
G1X0.0165S0
G1Y0.0039S0
G1X-0.0165S0
G1X-0.0449S600
G1X-0.0164S0
G1Y0.0039S0
G1X0.0164S0
G1X0.0449S600
G1X0.0165S0
G1Y0.004S0
G1X-0.0165S0
G1X-0.0449S600
G1X-0.0164S0
G1X-0.3133Y0.0039S0
G1X0.0165S0
G1X0.0541S600
G1X0.2591S0
G1X0.0449S600
G1X0.0497S0
G1X0.0402S600
G1X0.0164S0
G1X0.0146Y0.0039S0
G1X-0.0164S0
G1X-0.0673S600
G1X-0.0372S0
G1X-0.0449S600
G1X-0.0684S0
G1X-0.0449S600
G1X-0.1303S0
G1X-0.0866S600
G1X-0.1417S0
G1X-0.0483S600
G1X-0.19S0
G1X-0.0484S600
G1X-0.0164S0
G1Y0.004S0
G1X0.0164S0
G1X0.0484S600
G1X0.19S0
G1X0.0483S600
G1X0.1306S0
G1X0.1085S600
G1X0.1195S0
G1X0.0449S600
G1X0.0684S0
G1X0.0449S600
G1X0.0285S0
G1X0.0862S600
G1X0.0164S0
G1X0.0073Y0.0039S0
G1X-0.0164S0
G1X-0.1004S600
G1X-0.0216S0
G1X-0.0449S600
G1X-0.0684S0
G1X-0.0449S600
G1X-0.1117S0
G1X-0.1246S600
G1X-0.1223S0
G1X-0.0483S600
G1X-0.19S0
G1X-0.0484S600
G1X-0.0164S0
G1Y0.004S0
G1X0.0164S0
G1X0.0484S600
G1X0.19S0
G1X0.0483S600
G1X0.1153S0
G1X0.1387S600
G1X0.1046S0
G1X0.0449S600
G1X0.0684S0
G1X0.0449S600
G1X0.016S0
G1X0.1129S600
G1X0.0164S0
G1X0.0053Y0.0039S0
G1X-0.0164S0
G1X-0.123S600
G1X-0.0112S0
G1X-0.0449S600
G1X-0.0684S0
G1X-0.0449S600
G1X-0.0994S0
G1X-0.15S600
G1X-0.1092S0
G1X-0.0483S600
G1X-0.19S0
G1X-0.0484S600
G1X-0.0164S0
G1Y0.0039S0
G1X0.0164S0
G1X0.0484S600
G1X0.19S0
G1X0.0483S600
G1X0.1042S0
G1X0.1601S600
G1X0.0943S0
G1X0.0449S600
G1X0.0684S0
G1X0.0449S600
G1X0.0068S0
G1X0.1327S600
G1X0.0164S0
G1X0.0044Y0.004S0
G1X-0.0164S0
G1X-0.1406S600
G1X-0.0033S0
G1X-0.0449S600
G1X-0.0684S0
G1X-0.0449S600
G1X-0.0895S0
G1X-0.1698S600
G1X-0.0993S0
G1X-0.0483S600
G1X-0.19S0
G1X-0.0484S600
G1X-0.0164S0
G1Y0.0039S0
G1X0.0164S0
G1X0.0484S600
G1X0.19S0
G1X0.0483S600
G1X0.0952S0
G1X0.1775S600
G1X0.0859S0
G1X0.0449S600
G1X0.0684S0
G1X0.1927S600
G1X0.0164S0
G1X0.0039Y0.0039S0
G1X-0.0164S0
G1X-0.0754S600
G1X-0.0187S0
G1X-0.1025S600
G1X-0.0684S0
G1X-0.0449S600
G1X-0.0823S0
G1X-0.08S600
G1X-0.0206S0
G1X-0.0841S600
G1X-0.0916S0
G1X-0.0483S600
G1X-0.19S0
G1X-0.0484S600
G1X-0.0164S0
G1Y0.004S0
G1X0.0164S0
G1X0.0484S600
G1X0.19S0
G1X0.0483S600
G1X0.0881S0
G1X0.07S600
G1X0.0536S0
G1X0.0683S600
G1X0.0786S0
G1X0.0449S600
G1X0.0684S0
G1X0.0884S600
G1X0.0465S0
G1X0.0649S600
G1X0.0164S0
G1X0.0029Y0.0039S0
G1X-0.0164S0
G1X-0.0602S600
G1X-0.0626S0
G1X-0.0799S600
G1X-0.0684S0
G1X-0.0449S600
G1X-0.0758S0
G1X-0.0624S600
G1X-0.0711S0
G1X-0.0646S600
G1X-0.0847S0
G1X-0.0483S600
G1X-0.19S0
G1X-0.0484S600
G1X-0.0164S0
G1Y0.0039S0
G1X0.0164S0
G1X0.0484S600
G1X0.19S0
G1X0.0483S600
G1X0.082S0
G1X0.0605S600
G1X0.0842S0
G1X0.0586S600
G1X0.0733S0
G1X0.0449S600
G1X0.0684S0
G1X0.0742S600
G1X0.0747S0
G1X0.0567S600
G1X0.0164S0
G1X0.0026Y0.004S0
G1X-0.0164S0
G1X-0.0546S600
G1X-0.0845S0
G1X-0.0691S600
G1X-0.0684S0
G1X-0.0449S600
G1X-0.0708S0
G1X-0.0566S600
G1X-0.0939S0
G1X-0.0579S600
G1X-0.0794S0
G1X-0.0483S600
G1X-0.19S0
G1X-0.0484S600
G1X-0.0164S0
G1Y0.0039S0
G1X0.0164S0
G1X0.0484S600
G1X0.19S0
G1X0.0483S600
G1X0.077S0
G1X0.0557S600
G1X0.1028S0
G1X0.0549S600
G1X0.0682S0
G1X0.0449S600
G1X0.0684S0
G1X0.0653S600
G1X0.093S0
G1X0.0519S600
G1X0.0165S0
G1X0.002Y0.004S0
G1X-0.0164S0
G1X-0.0506S600
G1X-0.1002S0
G1X-0.0615S600
G1X-0.0684S0
G1X-0.0449S600
G1X-0.0664S0
G1X-0.0536S600
G1X-0.1098S0
G1X-0.0539S600
G1X-0.0749S0
G1X-0.0483S600
G1X-0.19S0
G1X-0.0484S600
G1X-0.0164S0
G1Y0.0039S0
G1X0.0164S0
G1X0.0484S600
G1X0.19S0
G1X0.0483S600
G1X0.0729S0
G1X0.0525S600
G1X0.1163S0
G1X0.0522S600
G1X0.0647S0
G1X0.0449S600
G1X0.0684S0
G1X0.0588S600
G1X0.1059S0
G1X0.0496S600
G1X0.0164S0
G1X0.0018Y0.0039S0
G1X-0.0164S0
G1X-0.0483S600
G1X-0.1117S0
G1X-0.0561S600
G1X-0.0684S0
G1X-0.0449S600
G1X-0.063S0
G1X-0.0513S600
G1X-0.1219S0
G1X-0.0514S600
G1X-0.071S0
G1X-0.0483S600
G1X-0.19S0
G1X-0.0484S600
G1X-0.0164S0
G1Y0.004S0
G1X0.0164S0
G1X0.0484S600
G1X0.19S0
G1X0.0483S600
G1X0.0695S0
G1X0.0504S600
G1X0.1267S0
G1X0.0506S600
G1X0.0614S0
G1X0.0449S600
G1X0.0684S0
G1X0.0538S600
G1X0.1163S0
G1X0.0475S600
G1X0.0164S0
G1X0.0015Y0.0039S0
G1X-0.0164S0
G1X-0.0471S600
G1X-0.1202S0
G1X-0.0518S600
G1X-0.0684S0
G1X-0.0449S600
G1X-0.0599S0
G1X-0.0499S600
G1X-0.1312S0
G1X-0.0497S600
G1X-0.0679S0
G1X-0.0483S600
G1X-0.19S0
G1X-0.0484S600
G1X-0.0164S0
G1Y0.0039S0
G1X0.0164S0
G1X0.0484S600
G1X0.19S0
G1X0.0483S600
G1X0.0665S0
G1X0.0491S600
G1X0.1351S0
G1X0.0493S600
G1X0.0586S0
G1X0.0449S600
G1X0.0684S0
G1X0.0498S600
G1X0.1241S0
G1X0.0467S600
G1X0.0164S0
G1X0.0014Y0.004S0
G1X-0.0164S0
G1X-0.0463S600
G1X-0.1273S0
G1X-0.0484S600
G1X-0.0684S0
G1X-0.0449S600
G1X-0.0574S0
G1X-0.0489S600
G1X-0.1383S0
G1X-0.0486S600
G1X-0.0654S0
G1X-0.0483S600
G1X-0.19S0
G1X-0.0484S600
G1X-0.0164S0
G1Y0.0039S0
G1X0.0164S0
G1X0.0484S600
G1X0.19S0
G1X0.0483S600
G1X0.0643S0
G1X0.0481S600
G1X0.1416S0
G1X0.0204S600
G1X0.0842S0
G1X0.0449S600
G1X0.0684S0
G1X0.047S600
G1X0.1297S0
G1X0.0463S600
G1X0.0164S0
G1X0.001Y0.004S0
G1X-0.0164S0
G1X-0.0463S600
G1X-0.1319S0
G1X-0.0458S600
G1X-0.0684S0
G1X-0.0449S600
G1X-0.2472S0
G1X-0.0481S600
G1X-0.0633S0
G1X-0.0483S600
G1X-0.19S0
G1X-0.0484S600
G1X-0.0164S0
G1Y0.0039S0
G1X0.0164S0
G1X0.0484S600
G1X0.19S0
G1X0.0483S600
G1X0.0626S0
G1X0.0477S600
G1X0.2483S0
G1X0.0449S600
G1X0.0684S0
G1X0.0449S600
G1X0.1337S0
G1X0.0464S600
G1X0.0164S0
G1X0.001Y0.0039S0
G1X-0.0164S0
G1X-0.0464S600
G1X-0.1355S0
G1X-0.0441S600
G1X-0.0684S0
G1X-0.0449S600
G1X-0.2494S0
G1X-0.0473S600
G1X-0.0619S0
G1X-0.0483S600
G1X-0.19S0
G1X-0.0484S600
G1X-0.0164S0
G1Y0.004S0
G1X0.0164S0
G1X0.0484S600
G1X0.19S0
G1X0.0483S600
G1X0.0612S0
G1X0.047S600
G1X0.2504S0
G1X0.0449S600
G1X0.0684S0
G1X0.0434S600
G1X0.1371S0
G1X0.0462S600
G1X0.0164S0
G1X0.0006Y0.0039S0
G1X-0.0164S0
G1X-0.0458S600
G1X-0.1386S0
G1X-0.0429S600
G1X-0.0684S0
G1X-0.0449S600
G1X-0.2513S0
G1X-0.0467S600
G1X-0.0606S0
G1X-0.0483S600
G1X-0.19S0
G1X-0.0484S600
G1X-0.0164S0
G1Y0.0039S0
G1X0.0164S0
G1X0.0484S600
G1X0.19S0
G1X0.0483S600
G1X0.0602S0
G1X0.0466S600
G1X0.2518S0
G1X0.0449S600
G1X0.0684S0
G1X0.0424S600
G1X0.1396S0
G1X0.0458S600
G1X0.0164S0
G1X0.0006Y0.004S0
G1X-0.0164S0
G1X-0.046S600
G1X-0.1405S0
G1X-0.0419S600
G1X-0.0684S0
G1X-0.0449S600
G1X-0.2522S0
G1X-0.0466S600
G1X-0.0598S0
G1X-0.0483S600
G1X-0.19S0
G1X-0.0484S600
G1X-0.0164S0
G1Y0.0039S0
G1X0.0164S0
G1X0.0484S600
G1X0.19S0
G1X0.0483S600
G1X0.0594S0
G1X0.0465S600
G1X0.2527S0
G1X0.0449S600
G1X0.0684S0
G1X0.0414S600
G1X0.1414S0
G1X0.0462S600
G1X0.0164S0
G1X0.0002Y0.0039S0
G1X-0.0164S0
G1X-0.046S600
G1X-0.1421S0
G1X-0.0411S600
G1X-0.0684S0
G1X-0.0449S600
G1X-0.2531S0
G1X-0.0464S600
G1X-0.0591S0
G1X-0.0483S600
G1X-0.19S0
G1X-0.0484S600
G1X-0.0164S0
G1Y0.004S0
G1X0.0164S0
G1X0.0484S600
G1X0.19S0
G1X0.0483S600
G1X0.059S0
G1X0.2436S600
G1X0.056S0
G1X0.0449S600
G1X0.0684S0
G1X0.0411S600
G1X0.1425S0
G1X0.0458S600
G1X0.0164S0
G1Y0.0039S0
G1X-0.0162S0
G1X-0.0456S600
G1X-0.143S0
G1X-0.041S600
G1X-0.0684S0
G1X-0.0449S600
G1X-0.0559S0
G1X-0.2438S600
G1X-0.0589S0
G1X-0.0483S600
G1X-0.19S0
G1X-0.0484S600
G1X-0.0164S0
G1Y0.004S0
G1X0.0164S0
G1X0.0484S600
G1X0.19S0
G1X0.0483S600
G1X0.0587S0
G1X0.2441S600
G1X0.0558S0
G1X0.0449S600
G1X0.0684S0
G1X0.0409S600
G1X0.1433S0
G1X0.0456S600
G1X0.0164S0
G1Y0.0039S0
G1X-0.0163S0
G1X-0.0459S600
G1X-0.1432S0
G1X-0.0408S600
G1X-0.0684S0
G1X-0.0449S600
G1X-0.0557S0
G1X-0.2441S600
G1X-0.0588S0
G1X-0.0483S600
G1X-0.19S0
G1X-0.0484S600
G1X-0.0164S0
G1Y0.0039S0
G1X0.0164S0
G1X0.0484S600
G1X0.19S0
G1X0.0483S600
G1X0.059S0
G1X0.2438S600
G1X0.0558S0
G1X0.0449S600
G1X0.0684S0
G1X0.0409S600
G1X0.143S0
G1X0.0459S600
G1X0.0164S0
G1Y0.004S0
G1X-0.0166S0
G1X-0.0459S600
G1X-0.1425S0
G1X-0.0412S600
G1X-0.0684S0
G1X-0.0449S600
G1X-0.056S0
G1X-0.2435S600
G1X-0.0591S0
G1X-0.0483S600
G1X-0.19S0
G1X-0.0484S600
G1X-0.0164S0
G1Y0.0039S0
G1X0.0164S0
G1X0.0484S600
G1X0.19S0
G1X0.0483S600
G1X0.0593S0
G1X0.2431S600
G1X0.0562S0
G1X0.0449S600
G1X0.0684S0
G1X0.0416S600
G1X0.142S0
G1X0.0459S600
G1X0.0164S0
G1Y0.0039S0
G1X-0.0166S0
G1X-0.0459S600
G1X-0.1415S0
G1X-0.0419S600
G1X-0.0684S0
G1X-0.0449S600
G1X-0.0564S0
G1X-0.2426S600
G1X-0.0596S0
G1X-0.0483S600
G1X-0.19S0
G1X-0.0484S600
G1X-0.0164S0
G1Y0.004S0
G1X0.0164S0
G1X0.0484S600
G1X0.19S0
G1X0.0483S600
G1X0.06S0
G1X0.2418S600
G1X0.0568S0
G1X0.0449S600
G1X0.0684S0
G1X0.0422S600
G1X0.1411S0
G1X0.0458S600
G1X0.0164S0
G1X-0.0006Y0.0039S0
G1X-0.0164S0
G1X-0.0459S600
G1X-0.1399S0
G1X-0.0427S600
G1X-0.0684S0
G1X-0.0449S600
G1X-0.0573S0
G1X-0.2409S600
G1X-0.0604S0
G1X-0.0483S600
G1X-0.19S0
G1X-0.0484S600
G1X-0.0164S0
G1Y0.004S0
G1X0.0164S0
G1X0.0484S600
G1X0.19S0
G1X0.0483S600
G1X0.0608S0
G1X0.0472S600
G1X0.147S0
G1X0.0459S600
G1X0.0577S0
G1X0.0449S600
G1X0.0684S0
G1X0.0434S600
G1X0.1385S0
G1X0.0461S600
G1X0.0164S0
G1X-0.0005Y0.0039S0
G1X-0.0164S0
G1X-0.0463S600
G1X-0.137S0
G1X-0.0442S600
G1X-0.0684S0
G1X-0.0449S600
G1X-0.0582S0
G1X-0.0458S600
G1X-0.1462S0
G1X-0.0468S600
G1X-0.0616S0
G1X-0.0483S600
G1X-0.19S0
G1X-0.0484S600
G1X-0.0164S0
G1Y0.0039S0
G1X0.0164S0
G1X0.0484S600
G1X0.19S0
G1X0.0483S600
G1X0.0623S0
G1X0.0465S600
G1X0.1453S0
G1X0.0456S600
G1X0.0589S0
G1X0.0449S600
G1X0.0684S0
G1X0.0449S600
G1X0.1357S0
G1X0.0463S600
G1X0.0164S0
G1X-0.0008Y0.004S0
G1X-0.0164S0
G1X-0.0462S600
G1X-0.1342S0
G1X-0.0457S600
G1X-0.0684S0
G1X-0.0449S600
G1X-0.0596S0
G1X-0.0457S600
G1X-0.1435S0
G1X-0.0468S600
G1X-0.063S0
G1X-0.2867S600
G1X-0.0164S0
G1Y0.0039S0
G1X0.0164S0
G1X0.2867S600
G1X0.064S0
G1X0.0468S600
G1X0.1417S0
G1X0.0458S600
G1X0.0603S0
G1X0.0449S600
G1X0.0684S0
G1X0.0466S600
G1X0.1326S0
G1X0.0459S600
G1X0.0164S0
G1X-0.0009Y0.0039S0
G1X-0.0164S0
G1X-0.0461S600
G1X-0.1302S0
G1X-0.0479S600
G1X-0.0684S0
G1X-0.0449S600
G1X-0.0613S0
G1X-0.0459S600
G1X-0.1396S0
G1X-0.0467S600
G1X-0.0651S0
G1X-0.2867S600
G1X-0.0164S0
G1Y0.004S0
G1X0.0164S0
G1X0.2867S600
G1X0.0662S0
G1X0.0471S600
G1X0.1368S0
G1X0.0461S600
G1X0.0624S0
G1X0.0449S600
G1X0.0684S0
G1X0.0492S600
G1X0.1276S0
G1X0.0464S600
G1X0.0164S0
G1X-0.0011Y0.0039S0
G1X-0.0164S0
G1X-0.0466S600
G1X-0.1246S0
G1X-0.0509S600
G1X-0.0684S0
G1X-0.0449S600
G1X-0.0635S0
G1X-0.0462S600
G1X-0.134S0
G1X-0.0475S600
G1X-0.0674S0
G1X-0.2867S600
G1X-0.0164S0
G1Y0.004S0
G1X0.0164S0
G1X0.2867S600
G1X0.0689S0
G1X0.0478S600
G1X0.1305S0
G1X0.0465S600
G1X0.0649S0
G1X0.0449S600
G1X0.0684S0
G1X0.0527S600
G1X0.1211S0
G1X0.0469S600
G1X0.0164S0
G1X-0.0014Y0.0039S0
G1X-0.0164S0
G1X-0.0475S600
G1X-0.1169S0
G1X-0.0549S600
G1X-0.0684S0
G1X-0.0449S600
G1X-0.0664S0
G1X-0.0467S600
G1X-0.1266S0
G1X-0.0485S600
G1X-0.0704S0
G1X-0.2867S600
G1X-0.0164S0
G1Y0.0039S0
G1X0.0164S0
G1X0.2867S600
G1X0.0719S0
G1X0.0492S600
G1X0.1221S0
G1X0.0475S600
G1X0.0679S0
G1X0.0449S600
G1X0.0684S0
G1X0.0572S600
G1X0.1126S0
G1X0.0481S600
G1X0.0164S0
G1X-0.0016Y0.004S0
G1X-0.0164S0
G1X-0.0491S600
G1X-0.1073S0
G1X-0.0599S600
G1X-0.0684S0
G1X-0.0449S600
G1X-0.0697S0
G1X-0.0482S600
G1X-0.1168S0
G1X-0.0502S600
G1X-0.0737S0
G1X-0.2867S600
G1X-0.0164S0
G1Y0.0039S0
G1X0.0164S0
G1X0.2867S600
G1X0.0757S0
G1X0.0512S600
G1X0.1107S0
G1X0.0493S600
G1X0.0717S0
G1X0.0449S600
G1X0.0684S0
G1X0.0628S600
G1X0.1014S0
G1X0.0502S600
G1X0.0164S0
G1X-0.0019Y0.0039S0
G1X-0.0165S0
G1X-0.0511S600
G1X-0.0951S0
G1X-0.0662S600
G1X-0.0684S0
G1X-0.0449S600
G1X-0.0737S0
G1X-0.0507S600
G1X-0.1035S0
G1X-0.053S600
G1X-0.0777S0
G1X-0.2867S600
G1X-0.0164S0
G1Y0.004S0
G1X0.0164S0
G1X0.0484S600
G1X0.19S0
G1X0.0483S600
G1X0.0802S0
G1X0.0546S600
G1X0.0951S0
G1X0.0526S600
G1X0.0761S0
G1X0.0449S600
G1X0.0684S0
G1X0.0701S600
G1X0.0871S0
G1X0.0533S600
G1X0.0164S0
G1X-0.0022Y0.0039S0
G1X-0.0164S0
G1X-0.0551S600
G1X-0.0787S0
G1X-0.0745S600
G1X-0.0684S0
G1X-0.0449S600
G1X-0.0786S0
G1X-0.0549S600
G1X-0.0853S0
G1X-0.0571S600
G1X-0.0827S0
G1X-0.0483S600
G1X-0.19S0
G1X-0.0484S600
G1X-0.0164S0
G1Y0.0039S0
G1X0.0164S0
G1X0.0484S600
G1X0.19S0
G1X0.0483S600
G1X0.0854S0
G1X0.0607S600
G1X0.0731S0
G1X0.0583S600
G1X0.0811S0
G1X0.0449S600
G1X0.0684S0
G1X0.0796S600
G1X0.0684S0
G1X0.0576S600
G1X0.0164S0
G1X-0.0026Y0.004S0
G1X-0.0164S0
G1X-0.0613S600
G1X-0.0558S0
G1X-0.0859S600
G1X-0.0684S0
G1X-0.0449S600
G1X-0.0842S0
G1X-0.0632S600
G1X-0.0569S0
G1X-0.0657S600
G1X-0.0886S0
G1X-0.0483S600
G1X-0.19S0
G1X-0.0484S600
G1X-0.0164S0
G1Y0.0039S0
G1X0.0164S0
G1X0.0484S600
G1X0.19S0
G1X0.0483S600
G1X0.0918S0
G1X0.0756S600
G1X0.0307S0
G1X0.0731S600
G1X0.0874S0
G1X0.0449S600
G1X0.0684S0
G1X0.041S600
G1X0.0016S0
G1X0.0523S600
G1X0.0376S0
G1X0.0677S600
G1X0.0164S0
G1X-0.0036Y0.004S0
G1X-0.0164S0
G1X-0.1508S600
G1X-0.0048S0
G1X-0.041S600
G1X-0.0684S0
G1X-0.0449S600
G1X-0.0911S0
G1X-0.1718S600
G1X-0.0957S0
G1X-0.0483S600
G1X-0.19S0
G1X-0.0484S600
G1X-0.0164S0
G1Y0.0039S0
G1X0.0164S0
G1X0.0484S600
G1X0.19S0
G1X0.0483S600
G1X0.0997S0
G1X0.1639S600
G1X0.095S0
G1X0.0449S600
G1X0.0684S0
G1X0.041S600
G1X0.008S0
G1X0.1439S600
G1X0.0164S0
G1X-0.0039Y0.0039S0
G1X-0.0164S0
G1X-0.1363S600
G1X-0.0117S0
G1X-0.041S600
G1X-0.0684S0
G1X-0.0449S600
G1X-0.0995S0
G1X-0.1548S600
G1X-0.1043S0
G1X-0.0483S600
G1X-0.19S0
G1X-0.0484S600
G1X-0.0164S0
G1Y0.004S0
G1X0.0164S0
G1X0.0484S600
G1X0.19S0
G1X0.0483S600
G1X0.1093S0
G1X0.145S600
G1X0.1043S0
G1X0.0449S600
G1X0.0684S0
G1X0.041S600
G1X0.0155S0
G1X0.1276S600
G1X0.0164S0
G1X-0.0049Y0.0039S0
G1X-0.0164S0
G1X-0.118S600
G1X-0.0202S0
G1X-0.041S600
G1X-0.0684S0
G1X-0.0449S600
G1X-0.11S0
G1X-0.1335S600
G1X-0.1151S0
G1X-0.0483S600
G1X-0.19S0
G1X-0.0484S600
G1X-0.0164S0
G1Y0.0039S0
G1X0.0164S0
G1X0.0484S600
G1X0.19S0
G1X0.0483S600
G1X0.1214S0
G1X0.1206S600
G1X0.1166S0
G1X0.0449S600
G1X0.0684S0
G1X0.041S600
G1X0.0255S0
G1X0.1063S600
G1X0.0164S0
G1X-0.0069Y0.004S0
G1X-0.0164S0
G1X-0.0932S600
G1X-0.0317S0
G1X-0.041S600
G1X-0.0684S0
G1X-0.0449S600
G1X-0.1242S0
G1X-0.1049S600
G1X-0.1295S0
G1X-0.0483S600
G1X-0.19S0
G1X-0.0484S600
G1X-0.0164S0
G1Y0.0039S0
G1X0.0164S0
G1X0.0484S600
G1X0.19S0
G1X0.0483S600
G1X0.1395S0
G1X0.0852S600
G1X0.1339S0
G1X0.0449S600
G1X0.0684S0
G1X0.041S600
G1X0.0397S0
G1X0.0755S600
G1X0.0165S0
G1X-0.0137Y0.004S0
G1X-0.0164S0
G1X-0.05S600
G1X-0.161S0
G1X-0.0449S600
G1X-0.148S0
G1X-0.0561S600
G1X-0.1545S0
G1X-0.0483S600
G1X-0.19S0
G1X-0.0484S600
G1X-0.0164S0
G1Y0.0039S0
G1X0.0164S0
G1X0.0484S600
G1X0.19S0
G1X0.0483S600
G1X0.3586S0
G1X0.0449S600
G1X0.0164S0
G1Y0.0039S0
G1X-0.0164S0
G1X-0.0449S600
G1X-0.3586S0
G1X-0.0483S600
G1X-0.19S0
G1X-0.0484S600
G1X-0.0164S0
G1Y0.004S0
G1X0.0164S0
G1X0.0484S600
G1X0.19S0
G1X0.0483S600
G1X0.3586S0
G1X0.0449S600
G1X0.0164S0
G1Y0.0039S0
G1X-0.0164S0
G1X-0.0449S600
G1X-0.3586S0
G1X-0.0483S600
G1X-0.19S0
G1X-0.0484S600
G1X-0.0164S0
G1Y0.0039S0
G1X0.0164S0
G1X0.0484S600
G1X0.19S0
G1X0.0483S600
G1X0.3586S0
G1X0.0449S600
G1X0.0164S0
G1Y0.004S0
G1X-0.0164S0
G1X-0.0449S600
G1X-0.3586S0
G1X-0.0483S600
G1X-0.19S0
G1X-0.0484S600
G1X-0.0164S0
G1Y0.0039S0
G1X0.0164S0
G1X0.0484S600
G1X0.19S0
G1X0.0483S600
G1X0.3586S0
G1X0.0449S600
G1X0.0164S0
G1Y0.004S0
G1X-0.0164S0
G1X-0.0449S600
G1X-0.3586S0
G1X-0.0483S600
G1X-0.19S0
G1X-0.0484S600
G1X-0.0164S0
G1Y0.0039S0
G1X0.0164S0
G1X0.0484S600
G1X0.19S0
G1X0.0483S600
G1X0.3586S0
G1X0.0449S600
G1X0.0164S0
G1Y0.0039S0
G1X-0.0164S0
G1X-0.0449S600
G1X-0.3586S0
G1X-0.0483S600
G1X-0.19S0
G1X-0.0484S600
G1X-0.0164S0
G1Y0.004S0
G1X0.0164S0
G1X0.0484S600
G1X0.19S0
G1X0.0483S600
G1X0.3586S0
G1X0.0449S600
G1X0.0164S0
G1Y0.0039S0
G1X-0.0164S0
G1X-0.0449S600
G1X-0.3586S0
G1X-0.0483S600
G1X-0.19S0
G1X-0.0484S600
G1X-0.0164S0
G1Y0.0039S0
G1X0.0164S0
G1X0.0484S600
G1X0.19S0
G1X0.0483S600
G1X0.3586S0
G1X0.0449S600
G1X0.0164S0
G1Y0.004S0
G1X-0.0164S0
G1X-0.0449S600
G1X-0.3586S0
G1X-0.0483S600
G1X-0.19S0
G1X-0.0484S600
G1X-0.0164S0
G1Y0.0039S0
G1X0.0164S0
G1X0.0484S600
G1X0.19S0
G1X0.0483S600
G1X0.3586S0
G1X0.0449S600
G1X0.0164S0
G1Y0.0039S0
G1X-0.0164S0
G1X-0.0449S600
G1X-0.3586S0
G1X-0.0483S600
G1X-0.19S0
G1X-0.0484S600
G1X-0.0164S0
G1Y0.004S0
G1X0.0164S0
G1X0.0484S600
G1X0.19S0
G1X0.0483S600
G1X0.3586S0
G1X0.0449S600
G1X0.0164S0
G1Y0.0039S0
G1X-0.0164S0
G1X-0.0449S600
G1X-0.3586S0
G1X-0.0483S600
G1X-0.19S0
G1X-0.0484S600
G1X-0.0164S0
G1Y0.004S0
G1X0.0164S0
G1X0.0484S600
G1X0.19S0
G1X0.0483S600
G1X0.3586S0
G1X0.0449S600
G1X0.0164S0
G1Y0.0039S0
G1X-0.0164S0
G1X-0.0449S600
G1X-0.3586S0
G1X-0.0483S600
G1X-0.19S0
G1X-0.0484S600
G1X-0.0164S0
G1Y0.0039S0
G1X0.0164S0
G1X0.0484S600
G1X0.19S0
G1X0.0483S600
G1X0.3586S0
G1X0.0449S600
G1X0.0164S0
G1Y0.004S0
G1X-0.0164S0
G1X-0.0449S600
G1X-0.3586S0
G1X-0.0483S600
G1X-0.19S0
G1X-0.0484S600
G1X-0.0164S0
G1Y0.0039S0
G1X0.0164S0
G1X0.0484S600
G1X0.19S0
G1X0.0483S600
G1X0.3586S0
G1X0.0449S600
G1X0.0164S0
G1Y0.0039S0
G1X-0.0164S0
G1X-0.0449S600
G1X-0.3586S0
G1X-0.0483S600
G1X-0.19S0
G1X-0.0484S600
G1X-0.0164S0
G0X0.0164Y0.0033
; Layer C00
G1Y-0.3656S200F236.22
G1X0.0484
G1Y0.1722
G1X0.19
G1Y-0.1722
G1X0.0483
G1Y0.3656
G1X-0.0483
G1Y-0.1501
G1X-0.19
G1Y0.1501
G1X-0.0484
G0X0.4139Y-0.1564
; Layer C00
G1X0.0063Y0.0064
G1X0.007Y0.0056
G1X0.0077Y0.0046
G1X0.0082Y0.0036
G1X0.0085Y0.0026
G1X0.0089Y0.0015
G1X0.0092Y0.0004
G1X0.0095Y-0.0004
G1X0.0092Y-0.0017
G1X0.0088Y-0.0029
G1X0.0083Y-0.0041
G1X0.0077Y-0.0051
G1X0.007Y-0.0061
G1X0.0061Y-0.0071
G1X0.0052Y-0.008
G1X0.0042Y-0.0097
G1X0.0032Y-0.0101
G1X0.0021Y-0.0104
G1X0.0011Y-0.0105
G1X-0.1478
G1X0.0012Y0.0117
G1X0.0028Y0.0113
G1X0.0043Y0.0109
G1X0.0057Y0.0102
G1X0.0056Y0.0073
G0X-0.0426Y0.0143
; Layer C00
G1X-0.0067Y-0.0104
G1X-0.0057Y-0.0112
G1X-0.005Y-0.0134
G1X-0.0039Y-0.0138
G1X-0.0026Y-0.014
G1X-0.0014Y-0.0143
G1X-0.0006Y-0.0152
G1X0.0005Y-0.0152
G1X0.0016Y-0.0152
G1X0.0027Y-0.015
G1X0.0035Y-0.0124
G1X0.0047Y-0.012
G1X0.006Y-0.0114
G1X0.0072Y-0.0108
G1X0.0122Y-0.0137
G1X0.0143Y-0.0114
G1X0.0159Y-0.0089
G1X0.0174Y-0.0061
G1X0.0127Y-0.0027
G1X0.0129Y-0.0017
G1X0.0129Y-0.0007
G1X0.013Y0.0003
G1X0.0149Y0.0015
G1X0.0146Y0.0034
G1X0.0141Y0.0051
G1X0.0133Y0.0069
G1X0.015Y0.0115
G1X0.0127Y0.0138
G1X0.0102Y0.0158
G1X0.0073Y0.0174
G1X0.0031Y0.0098
G1X-0.0465Y0.0057
G1X-0.0052Y-0.0126
G1X-0.0067Y-0.0119
G1X-0.0074Y-0.0093
G1X-0.0083Y-0.0076
G1X-0.0091Y-0.0057
G1X-0.0103Y-0.004
G1X-0.0108Y-0.0024
G1X-0.0139Y-0.0008
G1X-0.0139Y0.0014
G1X-0.0097Y0.0027
G1X-0.0091Y0.0038
G1X-0.0085Y0.005
G1X-0.0078Y0.006
G1X-0.0069Y0.0069
G1X-0.006Y0.0079
G1X-0.0049Y0.0085
G1X-0.0039Y0.0093
G1X-0.0051Y0.019
G1X-0.0022Y0.0195
G1X0.1974
G1X0.0003Y0.0143
G1X-0.0007Y0.0144
G1X-0.0015Y0.0142
G1X-0.0025Y0.0141
G1X-0.0035Y0.0126
G1X-0.0047Y0.0121
G1X-0.0059Y0.0116
G1X-0.007Y0.0109
G1X-0.0066Y0.0083
G1X-0.0074Y0.0074
G1X-0.008Y0.0068
G1X-0.0085Y0.0059
G1X-0.0091Y0.0051
G1X-0.0095Y0.0042
G1X-0.01Y0.0033
G1X-0.0103Y0.0024
G1X-0.0159Y0.002
G1X-0.016
G1X-0.0159Y-0.0015
G1X-0.0157Y-0.0034
G1X-0.0118Y-0.0042
G1X-0.0111Y-0.0054
G1X-0.0105Y-0.0066
G1X-0.0096Y-0.0077
G1X-0.0088Y-0.0086
G1X-0.0078Y-0.0096
G0X0.274Y0.1421
; Layer C00
G1Y-0.3656
G1X0.0449
G1Y0.3656
G1X-0.0449
G0X0.1932Y-0.1409
; Layer C00
G1X0.0066Y0.0041
G1X0.0082Y0.0036
G1X0.0085Y0.0022
G1X0.0087Y0.0009
G1X0.0086Y-0.0003
G1X0.0085Y-0.0016
G1X0.0083Y-0.0028
G1X0.0078Y-0.0041
G1X0.0072Y-0.0052
G1X0.0092Y-0.009
G1X0.0075Y-0.0102
G1X0.0059Y-0.0113
G1X0.004Y-0.0121
G1X0.0044Y-0.025
G1X0.0009Y-0.0252
G1X-0.0025Y-0.025
G1X-0.0059Y-0.0247
G1X-0.0069Y-0.0144
G1X-0.0097Y-0.0126
G1X-0.0122Y-0.0101
G1X-0.0142Y-0.0075
G1X-0.007Y-0.002
G1X-0.0071Y-0.0012
G1X-0.0072Y-0.0004
G1X-0.0072Y0.0004
G1X-0.0123Y0.0028
G1X-0.0115Y0.0051
G1X-0.0103Y0.0072
G1X-0.0088Y0.0091
G1X-0.0064Y0.0093
G1X-0.0051Y0.01
G1X-0.0038Y0.0105
G1X-0.0024Y0.0111
G1X-0.0025Y0.0199
G1X-0.0004Y0.02
G1X0.0016Y0.02
G1X0.0038Y0.0197
G1X0.0028Y0.0089
G1X0.0038Y0.0085
G1X0.0046Y0.008
G1X0.0054Y0.0075
G1X0.0052Y0.0059
G1X0.0057Y0.0053
G1X0.0062Y0.0047
G0X-0.0314Y0.0151
; Layer C00
G1X-0.0075Y-0.0094
G1Y0.0344
G1X-0.041
G1Y-0.3663
G1X0.0449
G1Y0.1289
G1X0.0068Y-0.0075
G1X0.0074Y-0.0067
G1X0.0081Y-0.0057
G1X0.0087Y-0.0048
G1X0.0091Y-0.0038
G1X0.0096Y-0.0027
G1X0.0098Y-0.0017
G1X0.0101Y-0.0005
G1X0.0152Y0.0011
G1X0.0148Y0.0032
G1X0.0144Y0.0054
G1X0.0142Y0.0077
G1X0.0133Y0.0099
G1X0.0116Y0.0118
G1X0.0097Y0.0133
G1X0.0076Y0.0148
G1X0.0065Y0.0168
G1X0.0045Y0.0181
G1X0.0027Y0.0185
G1X0.001Y0.0191
G1X-0.0008Y0.0192
G1X-0.0024Y0.0176
G1X-0.0042Y0.0173
G1X-0.0059Y0.0163
G1X-0.0073Y0.0149
G1X-0.009Y0.0132
G1X-0.0106Y0.0114
G1X-0.0121Y0.0097
G1X-0.0136Y0.0077
G1X-0.0144Y0.0054
G1X-0.0154Y0.0032
G1X-0.0165Y0.0011
G1X-0.0088Y-0.0002
G1X-0.0087Y-0.0011
G1X-0.0086Y-0.0017
G1X-0.0085Y-0.0026
G1X-0.0098Y-0.0046
G1X-0.0091Y-0.0059
G1X-0.0084Y-0.0069
G1X-0.0074Y-0.0079
M9
G1S0
M5
; return to starting pos
G0 X-0.8071Y-0.3413
;USER END SCRIPT
34
;USER END SCRIPT
M2
