Hey Hunter, Got mine working while working with support.
Try right clicking the lightburn tab and selecting troubleshoot compatibility. My computer put it into windows 8 compatibility mode and it started working
Sweet - that was me on the support email with those. Weāre the same folks in both places.
He sent me a trial version through some other contact and mine is working too. tonight ill finish up with the installing it
ok got this to the target aliment mode but I do not get the red target to show up to place over the targets ?
never mind I didnāt double click just was single clicking, operator error DUAAA
Oz, Iām having the same trouble with windows 10, 8mp camera. I right clicked the Lightburn tab and followed the procedure to test compatibility mode: for Windows 8 and that didnt solve the problem. Is the trial version you sent to Hunter a viable option for me?
Check the other things first - Your camera security settings should be set to allow applications to access the camera. If that isnāt set, nothing will help, so check that first.
I too am having trouble getting the latest version 9.09 of Lightburn software to recognize the new 8mp Lightburn camera. Windows 10 camera app shows the camera without issues. In the Lightburn software, the camera shows up in the Camera Control dropdown box as well as the Lens Calibration Wizard but the software locks up when trying to go any further. There is a note at the bottom of the software that states āNo Device Foundā
If it locks up, itās because you didnāt cover the honeycomb bed of the machine, and the code is seeing thousands of circles.
This is what Rick did , I went back and did this and it worked for me to
Windows 10 recently pushed updates that changed a bunch of permissions related to cameras, which I believe is why weāre seeing so much of this suddenly.
Go through this list first:
If you still donāt have an image, reply here and Iāll send you a link to an update with the new camera code. I may try to push that release forward a little just to try to resolve this sooner.
I checked the camera security settings. Allow apps to access camera and allow desktop apps to access camera are set to ON. One new thing I did discover is that when the Lightburn software locks up (Not responding), if I unplug the cameraās usb connection, the software not responding stops. I also changed the compatibility mode to Windows 8 but that didnāt seem to make any difference.
may i please have link to get my 2 cameras working
Good news!! This release seems to have solved the issue. The camera now appears in the Lightburn software calibration window. Thanks for the quick response.
It will have another problem when you try to run the alignment - thereās some test code in it that Iām in the process of removing, and Iāll be posting a new one in a few minutes. Wait about 10 minutes and download again.
Ok, new beta is posted.
The camera target alignment went as expected, however, when it came to framing the image with the laser, the laser head ran to the upper left corner and did not run the sample image frame perimeter. I tried to adjust the scale factor to various amounts but it did not seem to help.
I have no idea what you just said. The camera target alignment is the process that lets you frame, but you just said that went as expected, so Iām confused.
I just ran the Calibrate Camera Alignment wizard, used the scale appropriate for my test machine, and it framed where it was supposed to. Can you describe the issue youāre having in more detail? Remember, I canāt see what you see, so you have to spell it out.
