Stopped during project
I Started the project and it stopped after a few minutes. It is small enough but when I try to frame it this Alarm will show
ALARM:11
On or near line 0:
The project is small so size can`t be it.
What am I missing?
On or near line Zero is ‘a tell’ that there’s a problem with the output early in the framing.
Is your project an image file that you’ve imported, or is it made of several lines drawn in LightBurn, or drawn in other software and imported?
Alarm codes are 1-10 in the original grbl. We need some more info from your Console window in LightBurn to determine which GCode variant you’re getting alarm messages from.
The first communication from your laser engraver after connecting to LightBurn usually offers the grbl version number, a calendar date and some memory stats.
Please copy that information (from the Console window in LightBurn - and paste it into a reply) here so we can assist further.
First it was a download but I also tried just a circle.
This was when I started it again.
Waiting for connection…
00,0.000,0.000>
ok
ALARM:11
Homing
QC V2.1.
Grbl 1.2h [‘$’ for help]
[MSG:‘$H’|‘$X’ to unlock]
[MSG:Caution: Unlocked]
ok
And this is shown when I draw a small circle, put it in the middle of the field
ok
<Idle|MPos:0.000,0.000,0.000|Bf:199,512|FS:0,0|WCO:0.000,0.000,0.000>
ok
<Idle|MPos:0.000,0.000,0.000|Bf:199,512|FS:0,0|Ov:100,100,100>
ok
Starting stream
ALARM:11
On or near line 0:
Stream completed in 0:01
ok
QC V2.1.
ok
I can put the Laser on every position but if I start the project it will go into the corner and just stop.
Can’t believe I wrote this, but it may help…
