Weburn: WeCreat Vision to Lightburn compatibility bridge
Hi everyone!
I’ve managed to control the WeCreat Vision “directly” (more on that in a bit) from LightBurn! :partying_face:
TL;DR github repo
Currently runs on Linux… should compile and work for Windows or Mac.
You need a null-modem software like tty0tty or com0com
  1. Download weburn here (x86_64)
  2. Run weburn-bridge.sh
  3. Set up Lightburn with the gcode from WeCreat
  4. Modify the start gcode by adding “M14S0” on the line before “M14S1”
  5. Point LightBurn to /dev/ttyS30
  6. Enjoy!
First, some words of caution: put the device on a private net, sandbox it, whatever. The security is ABYSMAL. I had to set up a separate wifi network with downgraded security so that it would even connect… then checked for open ports and there’s 22, 8082 and 8080
:rotating_light: It has all the red flags of early IoT devices
22 is ssh (haven’t tried/needed to connect)
8082 is a directory listing (Mongoose ?) of the entire filesystem… even /etc/shadow is visible, the ssh config is visible and allowing root password login… ancient kernel… etc.
8080 is where the magic happens :smiley:
Endpoints on port 8080:
Using our buddy Wireshark, I’ve found the following endpoints on port 8080:
(Obviously, replace the ip address with the correct one)
Camera image
(WIP virtual webcam … another day)
curl -X GET "http://192.168.1.15:8080/camera/take_photo"
Returns a full frame 4032px × 3024px wide-angle jpeg.
Camera current calibration data
(There’s probably one to run the calibration, I’ll check later)
curl -X GET "http://192.168.1.15:8080/device/camera/download"
Returns JSON:
  "topData": {
    "points": [
        "x": 823,
        "y": 817
        "x": 1870,
        "y": 813
        "x": 2968,
        "y": 813
        "x": 823,
        "y": 1546
        "x": 1868,
        "y": 1541
        "x": 2963,
        "y": 1537
        "x": 819,
        "y": 2275
        "x": 1867,
        "y": 2267
        "x": 2962,
        "y": 2259
    "xy": 2145,
    "f": 1795.1331081081082
  "bottomData": {
    "points": [
        "x": 310,
        "y": 509
        "x": 1830,
        "y": 501
        "x": 3422,
        "y": 505
        "x": 307,
        "y": 1567
        "x": 1828,
        "y": 1561
        "x": 3418,
        "y": 1554
        "x": 306,
        "y": 2625
        "x": 1826,
        "y": 2616
        "x": 3413,
        "y": 2599
    "xy": 3112,
    "f": 1788.558918918919
  "middleData": {
    "points": [
        "x": 611,
        "y": 690
        "x": 1853,
        "y": 686
        "x": 3154,
        "y": 686
        "x": 611,
        "y": 1554
        "x": 1852,
        "y": 1549
        "x": 3149,
        "y": 1544
        "x": 608,
        "y": 2419
        "x": 1850,
        "y": 2409
        "x": 3148,
        "y": 2399
    "xy": 2543,
    "f": 1784.5674324324323
  "customThickness": 0.35,
  "factoryParameter": {
    "f": 1755.4864864864865,
    "points": [
        "x": 322,
        "y": 481
        "x": 1835,
        "y": 491
        "x": 3415,
        "y": 498
        "x": 313,
        "y": 1534
        "x": 1831,
        "y": 1537
        "x": 3414,
        "y": 1540
        "x": 315,
        "y": 2588
        "x": 1830,
        "y": 2586
        "x": 3409,
        "y": 2581
    "topData": {
      "points": [
          "x": 821,
          "y": 789
          "x": 1872,
          "y": 797
          "x": 2973,
          "y": 801
          "x": 818,
          "y": 1521
          "x": 1870,
          "y": 1524
          "x": 2970,
          "y": 1527
          "x": 815,
          "y": 2254
          "x": 1869,
          "y": 2253
          "x": 2969,
          "y": 2252
      "offset": {
        "x": 0,
        "y": 0
      "xy": 2152,
      "f": 1785.5783783783784
    "bottomData": {
      "points": [
          "x": 322,
          "y": 481
          "x": 1835,
          "y": 491
          "x": 3415,
          "y": 498
          "x": 313,
          "y": 1534
          "x": 1831,
          "y": 1537
          "x": 3414,
          "y": 1540
          "x": 315,
          "y": 2588
          "x": 1830,
          "y": 2586
          "x": 3409,
          "y": 2581
      "offset": {
        "x": 0,
        "y": 0
      "xy": 3093,
    "middleData": {
      "points": [
          "x": 608,
          "y": 657
          "x": 1857,
          "y": 667
          "x": 3162,
          "y": 671
          "x": 603,
          "y": 1526
          "x": 1854,
          "y": 1529
          "x": 3159,
          "y": 1532
          "x": 602,
          "y": 2396
          "x": 1852,
          "y": 2394
          "x": 3157,
          "y": 2392
      "offset": {
        "x": 0,
        "y": 0
      "xy": 2554,
      "f": 1773.9945945945947
Auto-focus
The following focuses the laser at x=100mm, y=100mm (offset is for the red laser)
curl -X GET "http://192.168.1.15:8080/device/camera/measure_distance?x=112&y=118"
Returns JSON; “distance” is the value you want to feed LightBurn. Errors measuring will return 0 for both.
  "distance": -83.73999786376953,
  "height-z": 16.260000228881836
Pause
curl -X POST "http://192.168.1.15:8080/process/control?action=0"
Returns JSON. To Resume, press the button.
{ "code" : 0, "result" : "ok" }
Cancel and return to 0,0,0
curl -X POST "http://192.168.1.15:8080/process/control?action=2"
Returns JSON
Get current status
curl -X POST "http://192.168.1.15:8080/process/status"
Returns JSON
{ "code": 0, "status": "", "result": 0 }
Send arbitrary gcode to be executed immediately
:warning: WARNING THIS GCODE WILL RUN REGARDLESS OF THE LID POSITION. Please remember to wear safety glasses. :sunglasses:
#!/bin/bash
CONTENT=M27 # replace "M27" with $1 and use a command-line arg!
FILE=$CONTENT\x0a\x0d
SUM=($(echo -n $FILE | md5sum))
echo $FILE | curl --data-binary "@-" -X POST "http://192.168.1.15:8080/test/cmd/mcu?md5=${SUM[0]^^}"
Runs the gcode in content (not sure if the \n\r is necessary but whatevs)
If the checksum is wrong, the returned JSON will have a calc_sum field and it won’t run.
The checksum has to be uppercase.
Go to Z pos (instead of auto-focus every time)
Send this gcode using the previous example to focus for a surface at 16mm
G0Z-84
Alternatively, just do this in LightBurn…
Bulk send gcode
This would be the equivalent of “Saving gcode and uploading it through WeCreat MakeIt!”
#!/bin/bash
FILE=$1
SUM=($(md5sum $FILE))
cat $FILE | curl --data-binary "@-" -X POST "http://192.168.1.15:8080/process/upload?md5=${SUM[0]^^}"
After uploading, you need to press the button so the program will run on the laser. The usual safety measures work as usual here.
…and more! (I’ll be back)
Since I don’t wanna be running scripts like this every time
I wrote a little program that acts as a bridge.
I’ll be uploading it to github later in the day.
To Get it running on my Arch installation, I need to have the tty0tty kernel module loaded, and move /rename of the devices to /dev/ttySX (I’m using 30 but that doesn’t really matter)
The gist of it is: Passes any short commands from LightBurn using the arbitrary gcode endpoint, and I added M14S0 (laser fan off) just before the M14S1 (laser fan on) in the custom gcode / user start script. As soon as “M14S0” is detected, the program switches into bulk mode, listens to all the gcode until M2 , uploads it to the bulk send endpoint and waits for the machine to return to waiting status, upon which it goes back to passthrough mode.
Smart
Any chance that Wecreat could get or wants to get involved to , maybe API this and be a bit more secure?
Could be extreamly useful.
In other words, what i am asking is, have Wecrate been involved or informed in any way of this repo?
They haven’t been involved… most I got was “it will be compatible, it’s WIP” but that was a month or two ago.
I guess they could document the api officially; what we have access to is a REST API – I just did an unofficial one.
As for contacting them, I was waiting to be let into their facebook users group, which seems to be the closest to a forum, to post this but I guess I should just send support an email :sweat_smile:
So… if anyone from WeCreat is reading this — could you please clear some stuff up? what’s up with the serial port? Baud rate? Specific GRBL quirks?
well you done half of the work, issue is - depending where their mindset is - they can also now close it once its been “discovered” :stuck_out_tongue:
never know
i have access to wecreat facebook group, is not very active
China is on holidays until next monday so maybe we got to give them time
Would be great if they could get on your repo and clean/fix/Help
Then this means lightburn could - potentially and hypotetically - also use it
Had to be officially supported i would imagine
@Rick
Thoughts?
I’m hoping they upgrade the security in terms of OS access (maybe that’s just the simple update route) --I don’t mind if they block 8082 or 22
but the laser control api itself on 8080 might not be worth covering up… this really unlocks a bunch of customers for them who would otherwise be put off by the current LightBurn support.
As for LightBurn devs using it, I’m all for it! That’s why I documented the api instead of just posting the bridge utility.
First item on my todo list includes making it multi-threaded so control commands can be sent at any time even as bulk processing happens, but the bridge is pretty usable for a 12h hack. :smiley:
agreed,
It would depend a lot on the terms of the API i would imagine, i am 99% sure it had to be officially supported and public and under a “usable” license agreement.
Is great work you done here thought, if nothing else as a case study!
watch a quick demo on youtube
I can’t comment on the timeline but I want to say that we have one of our developers with the WeCreat machine and he is working directly with their dev team to get native LB support.
At this time they are doing firmware changes to enable better communication between our machines based on the dev’s feedback and they are being very good about communication.
That’s great news! I guess this’ll be available as the workaround for the time being :smiley:
Thanks for your work and publishing it to the forum! I don’t want to discourage you at all. I LOVE seeing people do stuff like this. I’m going to send it to the dev that is working on it now. He will appreciate that you started with Linux support haha.
Y’all feel free to reach out! I just really had to satisfy that itch about not owning the hardware until I can use it to its capacity xD that and I wanted to stop using the other program through remote desktop :upside_down_face:
I’m the dev working on integration - and yeah, this is really cool. I’m the latest tux-head of the bunch at LightBurn, and many of us are finding what you did really neat.
WeCreat has been really good about sending us their API endpoints and the way they developed the API for their network tool, so we’ll be adding full API integration into LightBurn.
I have too many things on my plate to really dig into their firmware regarding IoT security, but I’ll confirm your port/security findings and pass them back to see if they can issue another security update :wink:
The first fix they made based on our feedback was to add support for spaces in the wifi SSID. This bodes well for their being receptive to what we’re pointing out as potential issues.
That said, I’m a bit less concerned about IoT security as I would be with a different piece of hardware - we always recommend users stay with their laser while it’s running. If it’s networked this is even more imperative.
@2ktsch I’ll ping you via DM when I have a beta ready to test the integration I’ll build up. Would be good having a separate pair of hands test out what I’ll build. I suspect it’ll be a couple of weeks at least.
This great news. Im about to put out a review of this machine and its biggest issue is its own software and then lack of compatibility with Lightburn. To know this is hopefully all going to be resolved is excellent
This is a great job you’ve done
Can’t wait for further refinement on the compatibility. Will be nice when it doesn’t just freeze on the 5th move or something like it for me.
Also, if it could work over wifi eventually that would be amazingly more useful to me.
@Firecul I’ve run a decently long job over USB with LightBurn and not had any freeze… They just put out a firmware update, which you still need to use their software suite to install. But perhaps that was fixed?
I had the latest sw and fw (for wecreat and Lightburn) at the time of posting.
I did manage to borrow a windows laptop and try that and it was able to complete a job with the same drivers my pc is using. So not sure what is up there.
What I found strange is the laptop sees 2 com ports with the laser plugged in but my pc only 1.
That’s interesting. I think the firmware update came out around that time?
Regarding the 2 com ports vs 1, that could indicate a difference in drivers available/installed. I don’t know how much I can share of the hardware’s data I was given, but I will say that you should only see 1 com port on Windows. The other “com” port isn’t one, in the sense that you won’t get a serial communication going over it. If you detect 2 USB devices that’s a bit more accurate.
