A 15W diode is input power not output. It will output approximately 3-5W, which is what you already have. The manufacturers are stating input power to make it sound better, and hope that you do not know the difference.
Generally speaking, if the laser is rated from 0 to 5w it’s output power, from 5 to 7w, it’s usually output power, and higher than that is rating input power, but that’s not always true. The best thing to do is read the fine print. The highest rated single diode emitter was a Nichia, at 6.5w. I’m not sure if that’s still true, but it likely is.
Hi LH, when you say you also cut 4mm plywood, what exactly do you mean by that? Will you be so kind and show what you work with (in 4mm) and the associated settings ?, I would love to learn how to cut 4mm plywood with my 5.5 watt laser. Thanks in advance.
I have not been clear enough with my wording, sorry for that. I would ask to show a picture with something you have cut in 4 mm (hoby) plywood because I am interested in your Lightburn parameters. I assume you use 100% power, but what speed and how many passes do you use to get a usable result, many thanks.
I cut 1/4" ply often for use in RC airplanes with 5W laser. I set the parameters to 100% power, speed to 6.35mm/min (which is approx. 1/4" in/min) and 5 passes.
I then focus lens to the top of the material and run it. This cuts about half the thickness. I then refocus the lens to 1/8" (use a scarp piece of ply) and run it again.
Total of ten passes with two focus settings. Takes a while, especially if you are cutting multiple shapes, but hey it works.
