I cannot get the last two updates to load on either computer. I have added lightburn to my PC-Matic whitelist. I am the administrator of the computer. I could use a hint on what needs to be done.
screen shot:
Windows 10
Thank you
screen shot:
Windows 10
Thank you
Did you whitelist lightburn or the installer? I suspect you’d need to whitelist the installer or simply disable PC-Matic for the installation.
There are several conditions that can cause this scenario but ultimately it comes down to OS or PC-Matic protections preventing the installation from happening.
You might start by trying to do the install as Administrator. A web search brings up some others:
Fixes to Unable To Execute Files In The Temporary Directory [Error 5] - EaseUS
I was having the same problem, found out MS defender was turned on and Malwarebytes was turned off after switching them it installed correctly.
You folks are a great community! Thanks for the advice. When I get it sorted out, I will post back to this thread to pay the knowledge forward.
Thanks again
OK - a fast 5 minutes and the problem was solved. Micrololin (Jeff) provided a link and the walk through to fix the permission issue. Thanks a million!
