Ok, downloads should be back to normal. But please let us know if you run into any further issues.
I can download installer exe file now with out problem but it will not run.
When I click on file the hourglass comes up for a second goes away and nothing happens. I think Endpoint Protection Service maybe stopping it.
Windows 11, iolo antivirus, Chrome
Your file has two duplicate points in the outer shape, and that was what was triggering the crash. I’ve fixed the bug that caused it to fail.
I check for duplicates…without “alarm”
Glad you can fix it
That’s not the intended use of the scissor tool. If you want to cut a single side off a square, just use the ‘D’ key when hovering over a line in Node Edit mode.
Duplicate nodes, not duplicate shapes. These two points have nodes that are almost on top of each other:
Select your big outer shape and click Edit > Optimize Selected Shapes, move the “Line fit” option up a single tick to 0.002.
This should be fixed in the next update as well. Adam will be cutting an update later this evening.
… otherwise it doesn’t look like me to have “disorder” in the drawings
I see the problem and thank you.
Release Candidate 3 of LightBurn 1.7.00 is available now here:
https://release.lightburnsoftware.com/LightBurn/RC/LightBurn-v1.7.00-RC-3/
This build includes the following updates:
- Fix issue with device selection index lookup
- Fix wizard crash with WeCreat camera
- Rename “default” capture resolution setting
- Increase maximum machine coordinates to 10 meters
- Improved PathWalker normal generation for end of path
- Disallow UI scaling when not supported for Copy Along Path
- Updated cursor / node size to have an additional large setting
- Fixed Scissor / trim tool crash
- Allow ShapeOptimizer to line fit even with 0 tolerance
RESPECT! Are you starting to support coal mining machines? ![]()
They need it for the bigger CO2 dot resolution. ![]()
We had a user complain that they couldn’t jog the full range of their large format fabric cutting machine - I think it was 8’ x 20’.
Yes, I can remember this wish of one of our friends.
It’s fine that something like this can be done too ![]()
14 posts were split to a new topic: LightBurn 1.7.00 RC - Linux Camera Issues
No complaints! Thanks for the change.
Great software… just started using it… 'tis my first laser cutter.
There’s a 1.7RC for Linux!!!
Halleluja!
I know I’m only a couple of licenses but I REALLY REALLY REALLY appreciate Linux support.
Riley
Running a Toshiba Tecra A50-E, 15,6”- Intel Quad Core 8th Gen i7- 8650U-32GB RAM-Super Fast 1TB M.2 SSD, Full HD - 1920 X 1080 - Windows 11 Pro laptop. Camera works just fine in last version of lightroom but version 1.7.00 it finds the camera and displays the working area but it will not update the overlay for some reason.
5 posts were split to a new topic: RC 1.7 - Dialog Box Crash MacMini M1
RC4 is now available here: Index of /LightBurn/RC/LightBurn-v1.7.00-RC-4/
With the following updates:
- Fixed inverted result logic for dpi sanity check
- Add Trim and Measure shortcuts to tooltip
- VarText: Add an option to remove newline preceding an empty field
- Laser: Fixed “cleaning pass” toggle tooltip
- Update Slovak translation
- Bugfix: Diacriticals skipping looped-back bezier segments
- Bugfix: mode selection/sorting logic
- Bump Linux version to use Qt 5.15.17 - should fix some existing camera issues
