Hi
i have problems with my ruida board and my new rotary
for the time being i connected it and moved it with the arrow keys in the movement area
I was able to determine here that all movements X/Y/Z and also the rotary are possible without any problems
also under
However, when I tried to press the test button here, only X and Y moved. The rotary did nothing here, even when I tried to laser a test, the rotary did not move
what can I do to get a correct rotary laser
That’s exactly what it is when I press test, my rotary doesn’t turn, but then the Y moves
especially since I can move X / Y / Z and rotary correctly with manual movement
but I can’t select the A when setting up rotary
on the other hand, my rotary chuck and roller can be used, which would be great if I could adjust both because the steps per revolution are different
If you don’t know (or care) how it’s connected, someone else will have to help you. Without the information I cannot, it’s a waste of time for everybody involved…
I highly doubt the diameter of your object is 80,000mm…
I said that the program should already know which axis is used to control my rotor, it is the U axis and the diameter of 80 mm is only there so that a diameter is specified at all, but that only leads away from the topic, namely that the rotary (U axis ) in the test and when lasering does not drive what it should
During the test, the Y axis, which should not move during the test or during rotary lasering, only moves manually to move home from the workpiece
There was a malicious link in the thread which has been deleted. The individual that posted it has been blocked from posting again and their account has been deleted.
If you’re getting strange advertisements and pop ups on your computer please use a virus scan tool to remove any malware that may have been launched on your computer.
