The unit responds properly when the “Home” button is clicked, moving the laser head to the left, then down to the bottom, but once it completes the homing sequence and I click the “Get Position” button, the X and Y positions show “-299”, not “0” like I’m expecting.
Also, I have to execute the $21=1, $22=1, and $23=3 every time I start LightBurn. I can save the settings under Machine Settings as an “.lbset” file, but how do I get LightBurn to load these settings on startup?
You likely have a coordinate offset set. Enter these commands into console and respond with results:
These GRBL settings are meant to be permanent when set and persist within the controller memory. However, some vendors deliberately disable this capability and these values cannot be updated at all or do not survive a power cycle. Sounds like that might be the case for you.
There’s no provision in LightBurn to auto-load something like this. You could potentially create a Macro in Console to set these quickly each time.
I’d suggesting going back to the vendor or manufacturer and complaining to see if there’s an update that can change this.
I started from square one, powering everything up. I executed the $21=1, $22=1, and $23=3 commands, then click the Home button. It homed as expected. I then entered the commands and here are the results:
[G54:0.000,0.000,0.000]
[G55:0.000,0.000,0.000]
[G56:0.000,0.000,0.000]
[G57:0.000,0.000,0.000]
[G58:0.000,0.000,0.000]
[G59:0.000,0.000,0.000]
[G28:0.000,0.000,0.000]
[G30:0.000,0.000,0.000]
[G92:0.000,0.000,0.000]
[TLO:0.000]
[PRB:0.000,0.000,0.000:0]
ok
<Idle|MPos:-299.000,-299.000,0.000|FS:0,0|Ov:100,100,100|A:F>
ok
Just seems odd that it homes properly, but reports the -299 values. Thanks!
Out of curiosity, I just experimented a bit. Using LaserGRBL, I changed and wrote the values to the controller. I restarted LaserGRBL, and the settings persisted. I then power-cycled the laser, started LaserGRBL, and the values were back to the original.
I’m guessing that it would take an update to the firmware to get it to permanently save the values, which would not happen any time soon. The Totem S doesn’t ship with the limit switches. You have to add them yourself. Seems goofy that they would have the connections on the mainboard for the switches but then not allow the values to be saved.
Since LightBurn has the ability to “Auto-home on Startup”, it wouldn’t take much to allow inclusion of the S21/S22/S23 commands along with the “Home” command. I’m going to submit an enhancement request to LightBurn.
Your firmware must assume that upper right is origin although you have it homing to lower left.
Try this:
$10=0 ; this changes your controller to report work coordinates instead of machine coordinates
G10 L2 P1 X-299 Y-299 ; sets a work offset to get you 0,0 for lower left
Is your actual working area 300,300? You may have an ease-off set that’s making it go to -299, -299 instead of -300,-300. You can adjust the specific values depending on how you want this to work.
There is an “ease-off”, so that explains the -299 as opposed to -300.
After executing “G10 L2 P1 X-299 Y-299”, it now reports “X=0 Y=0” after homing.
I experienced another issue yesterday that I need to trace further. I ran a simple project with two layers. The first was an engrave, the second a cut. When it finished the “engrave” layer, the head moved up to the right several centimeters and then back down before starting the “cut” layer. This worked ok because the object was really small. I then enlarged the object, and this time the head max’d out the travel to the upper right before the “cut” layer, causing the steppers to grind a bit. I’m not understanding why the head would move away from the object between layers. I just started using LightBurn yesterday, so I understand that I have a LOT to learn.
Since your coordinates were not correctly zeroed out yesterday I’m assuming you were working with Start from in the Laser window set to “current position”. If so, LightBurn won’t necessarily know where the laser is positioned on the machine and will be happy to send instructions that potentially crash the head.
I suggest you switch to Absolute Coords until you get very comfortable with how LightBurn and your laser work. Absolute Coords is very simple because your workspace in LightBurn matches 1:1 with your work area. So what you position in the upper left in LightBurn will correlate to the same position on your laser.
This will prevent most crash scenarios.
You may also want to configure soft-limits to be on ($20=1). This will prevent certain additional crash scenarios.
Regardless of the positioning method, why would the head move far away from the object between layers? The laser work area is 300mm x 300mm, and it started down in the lower left quadrant. The object (both layers) is only 30mm x 40mm, so if it started in the lower left corner for the first layer, I would expect it to return to that point when starting the second layer.
I believe that the issue was related to the setup prior to having the limit switches installed. LightBurn was set to “Current Position” instead of “Absolute Coords”. Now that I have everything setup, it worked properly.
Also, when I executed “G28”, the head moved to the back-right corner and ground the steppers. I’m assuming this is because the homing was handled by the controller board and not positioned by LightBurn.
I’ll hold off flashing a new firmware until I can be assured I won’t brick he unit!
When I click the “Home” icon in LightBurn. what command(s) are being sent to the printer? I ask because when I click the icon, it performs the expected homing sequence using the limit switches.
I believe that I need to move the limit switches to the back right instead of the front left. I initially went with front left because of a video I watched and that’s how it was done, plus, my 3D printers both home to the lower left and that’s what I’m used go.
When I send the commands to the laser to set using the homing switches in the lower/left, it head homes to the lower/left, but when I start a print, the head shoots to the back/right and grinds the steppers. It appears to be sending a different “home” command at the start of the job. I’m still learning about the gcodes as well as what the laser interprets.
After homing, move the laser to each corner of the machine and run ? in console. Respond with which corner and the output of the command for each please.
