I was using 0.09.01 and then updated to the 0.09.02 Win64 file.
I was running the scan power test grid which worked great. I wanted a cut grid so I changed everything form Scan to Line and changed the speeds range to 70-10mm/s and left power at 10-100. When it uploaded to the laser and ran the file it reached the bottom row, which was 10mm/s and traced the boxes but didn’t mark the wood. After testing several different things I tried a speed of 11mm/s and it worked fine. I tested down to 5mm/s but anything below 10.1mm/s doesn’t energize the tube. My analog current meter moves in the very low end at 10mm/s and below even though power was set to 100%. At 10.1mm/s and above the meter is in the expected range. I made several different shapes and have the same result.
In RDWorks everything fires as expected at 10mm/s and below.
I also tested several different layer colors to see if I missed something and all gave the same result.
Ruida RDC6442G controller
EFR 100w ZS1450 tube (10.3% is the lowest power I can make a faint line on paper)
Any help would be appreciated,
Thanks,
