LB_Rotary_test_line_360.txt (1001 Bytes)
LUBAN_Rotary_test_line_360.txt (1.3 KB)
After a significant hiatus, I noted some changes to the broken setup for the Snapmaker Rotary Module (added a B axis option) so grabbed an upgraded license to test this out. Sadly, it’s still broken.
Whilst the Rotary setup in LB works as expected when hitting the ‘TEST’ button, the generated g-code does not.
@LightBurn - I know the number of Snapmaker users is probably small, but as you came so far in supporting it in the past (thanks!!) I am wondering if a g-code breakdown might help with a fix?
Scenario - a 50mm cylinder [circ. 157.08] with a line circumscribing 360° as a single path test;
See below the generated code from the native ‘LUBAN’ software for the SM2.0 [I’ve scrubbed the thumbnail png from the header to condense the file] and the LB equivalent. Added comments per line.
LUBAN
;Header Start
;header_type: laser
;tool_head: levelTwoLaserToolheadForSM2
;machine: A350
;renderMethod: line
;file_total_lines: 49
;estimated_time(s): 50.546
;is_rotate: true
;diameter: 50
;max_x(mm): 0
;max_y(mm): 50.005
;max_z(mm): 0
;max_b(mm): 180.089
;min_x(mm): 0
;min_y(mm): 50
;min_b(mm): -179.75900000000001
;min_z(mm): 0
;work_speed(mm/minute): 500
;jog_speed(mm/minute): 3000
;power(%): 1
;work_size_x: 320
;work_size_y: 350
;origin: bottom-center
;thumbnail:
[REMOVED TO REDUCE FILESIZE]
;Header End
; Laser multi-pass, pass 1 with Z = 0
; G-code for laser engraving
; Generated by Snapmaker Luban
; G-code START <<<
G90 ;ABS positioning/coords
G21 ;Millimeter units
M106 P0 S255 ;FAN Index_0 ON, Full speed
G0 F3000 ;Set RAPID speed to 3000mm/min
G1 F500 ;Set FEEDRATE to 500mm/min
G0 X0.00 ;RAPID to X:0
G0 Y50.01 B-179.76 ;RAPID to Y50.01, ROTATE B -179.76°
M3 P1 S2 ;Laser ON, Power 1%, Power, S, as 8bit [integer]
M3 ;Laser ON, but could be quiery
G1 Y50.01 B-0.66 ;FEED @ Y50.01, ROTATE B to -0.66°
G1 Y50.01 B180.09 ;FEED,@ Y50.01, ROTATE B to 180.09°
M5 ;Laser OFF
G0 Y50.00 B0.17 ;RAPID to Y50.00, B0.17°
G92 B0.17 ;Specify B axis is at 0.17°
M107 P0 ;FAN Index_0 OFF
; G-code END <<<
G91 ;Relative position mode
G0 Z0 F150 ;RAPID to Z0 @ 150mm/min
LIGHTBURN
;Header Start
;header_type: laser
;file_total_lines:29
;max_x(mm): 238.5
;max_y(mm): 170
;max_z(mm): 0
;min_x(mm): 81.5
;min_y(mm): 170
;min_z(mm): 0
;Header End
; LightBurn 1.2.04
; SnapMaker device profile, user origin
; Bounds: X81.5 Y170 to X238.5 Y170
G0 X0 Y0 F0 ;RAPID to X0,Y0 @ 0mm/min [no feed?]
; Cut @ 500 mm/min, 1% power
M05 ;Laser OFF
G0 X-78.5 a0 F0 ;RAPID, X-78.5 [regular 3-axis move here and not B rotation]
;ROTATE A to 0° [assumed!?!]
;[should be Y:50 and B:-179.76]
; Layer Internal Cuts
M03 P1 S2.55 ;Laser ON, Power 1%, Power, S, as 8bit [float]
G1 X157 F500 ;FEED to X157 @ 500mm/min [regular 3-axis move here and not B rotation]
M107 ;FAN OFF
M05 ;Laser OFF
; return to user-defined finish pos
It appears the LB g-code for the most part is for regular 3-axis moves. No referencing for B-axis as set in the Rotary Setup options.
Is it possible to fix this?
Thanks in advance
