Getting your camera to work in the hellscape of Windows
Windows 10 and 11 have been cranking up permissions in recent updates, wreaking havoc with camera access for applications. Here is a list of things you can try to get it to behave:
  • If you have anti-virus software, that it is not set to block camera access
  • Check that your Windows security settings allow apps to access the camera.
    – To do this, click the Start menu, type “camera privacy” and click the ‘Camera Privacy Settings’ entry.
    – Check that ‘Allow apps to access your camera’ is enabled.
    – Scroll down below the list of Windows apps and check that ‘Allow desktop apps to access your camera’ is enabled too.
    – If LightBurn isn’t in that list, it should be.
    – You might need to reboot your machine and try again after the settings change.
  • You can try running LightBurn in ‘Compatibility Mode’ for Windows 8. Right-click the LightBurn app icon on the desktop, click the tab labeled ‘Compatibility’, check the box for ‘Run this program in compatibility mode for’ and choose Windows 8.
If none of these things works for you, contact us.
Lightburn camera no image
Camera Lens calibration issue
8MP LightBurn Camera (4K-W) × 1
Lightburn Camera and a question
Starting the Light burn camera
Windows 10 Camera Permissions - Possible Solution
"capture" button in lens calibration wizard not reacting
No image from light burn camera
Camera showing no image
Camera view not showing after update
K40 lightburn camera not working
Camera calibration help needed
Cannot install Creality Falcon 2 Pro camera Windows 7?
Lightburn 8mp 120 camera freezes and locks up software
LightBurn Camera No Image Win10
Camera on laser
Arducam 8MP IMX179 Help
Crash when camera loads
Kamera Kalibrierung funktioniert nicht (Camera calibration not working)
Head-mounted camera problem (No update overlay)
Why won't Lightburn open my ArduCam 8MP IMX179 Camera?
Win 10 does not see the new camera from Lightburn
Adding a Camera Freezes Lightburn
Second Comgrow Camera Not activating
I have a black screen in lightburn and the windows camera app
Camera shows images in other software, but not Lightburn
MIra 9 factory LightBurn Camera
Locked Up Camera
Camera issue problem
Lightburn Camera Won't Calibrate
Lightburn camera no image using "Custom Camera System"
Updated camera stoped
Camera shows up in list but feed no longer viewable
Lightburn Camera Issues - Not Working
Lightburn breakdown after selecting USB.Webcam
8MP Lightburn Camera no picture in lightburn
Where did the "exposure" and "brightness" settings go?
